Very good quality plug!
This product has been replaced by a new version, available here.
Brass plated connector ⌀4mm
This 3.5mm connector has a neat carbon finish. Its construction includes a gold-plated brass connector with painted metal capsule. They provide good conductivity and a durable mechanical strength.
This is a stereo connector (2 channels). There are two solder connectors in addition to the mass within the capsule.
This 3.5mm stereo jack plug comes with a protective seal to protect the welds as well as the conductors of the cable from twisting and tearing.
Jack type | 3.5mm / angled |
Contact materials | Brass |
Plating | Gold |
Max acceptable cable diameter | Ø 4mm |
Connection Type | Welding |
Weight | 10g |
Body dimensions | ⌀8.42 x 22.5mm |
Total length | 31.7 mm |
Total width | 28.3 mm |
Color | Black |
Max cable diameter (mm) | 4.0 |
Mounting type | To weld |
Connectic | Male |
Contacts number | 3 |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
