Female 3-pole 3.5mm Jack Socket Silver-plated
This 3.5mm jack socket has 3 poles and therefore works with TRS jacks. Ideal for PCB mounting as part of a DIY project, this socket will enable you to transmit a stereo or balanced mono signal. Its silver-plated contacts ensure a high level of conductivity and resistance to corrosion and oxidation.
Reference : 19402
1,30 €tax incl.
1,08 € tax excl.
Shipping date: 29-04-2025.
Jack 3.5mm Female Socket3-pole Silver-plated (TRS)
Photo de l'embase jack
Jack socket dimensions
Product typeJack Socket
Pole numbers3
COntact matérialCopper Alloy
COntact platingSilver
Rated voltage12V
Package1x Female 3-pole Jack 3.5mm Socket
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Contacts number3
This 3.5mm jack socket has 3 poles and therefore works with TRS jacks. Ideal for PCB mounting as part of a DIY project, this socket will enable you...
