Female Jack 3.5mm Stereo 4 Pins Connector Gold Plated Ø4mm (Unit)
This connector will allow you to design your own 3.5mm audio jack cables. This one benefits from gold plated contacts, ensuring both good electrical conductivity and resistance to oxidation. The connector accepts cables up to 4.3mm in diameter.
3.0 / 5
Reference : 6132
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 15-04-2025.
Jack 3.5mm Connector
Female stereo 4 pins gold plated Ø4mm (Unit)
Connecteur Jack 3.5mm femelle stéréo 4 pôles plaqué or Ø4mm (unité)
Product typeJack 3.5mm connector
Number of pins4
ChannelsStereo
Max cable diameterØ4.3mm
Contacts platingGold
Body materialPlastic
DimensionsØ8 x 28mm
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticFemale
Contacts number3
Moyen
Pas le top niveau qualité, mais il faut faut dire qu'il n'y a pas beaucoup de choix question prise femelle à ce niveau de prix. Utilisé comme interconnexion "originale" de câble de masse pour pouvoir permuter rapidement entre deux différents câbles de platine vinyle "maison".
This review has been posted for Female Jack 3.5mm Stereo 4 Pins Connector Gold Plated Ø4mm (Unit)
This connector will allow you to design your own 3.5mm audio jack cables. This one benefits from gold plated contacts, ensuring both good...
