Jack 3.5mm Socket Gold Plated Brass
This socket in 3.5mm jack format will allow you to easily create your headphone connectors in particular.
Reference : 12437
1,90 €tax incl.
1,58 € tax excl.
Jack 3.5mm Socket
Gold plated brass
embase jack 3.5
This 3.5mm 3-pin jack socket will allow you to create your own headphone connectors. It is made of brass (copper and zinc alloy) and gold-plated to ensure good conductivity and oxidation resistance.
Connector typeJack 3.5mm Socket
Pole number3
Screw thread total lenght (without nut)5mm
Body lenght11.5mm
Screw thread diameter6mm
Body diameter8mm
Maximum panel thickness3mm
PlatingGold
embase jack 3.5mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Contacts number3
2 reviews
Impeccable
Très bien, compact, qualité au top
This review has been posted for Jack 3.5mm Socket Gold Plated Brass
Pas solide du tout
Les pattes se sont soit cassées, soit ont fondu quand j'ai soudé.
Je déconseille
