Jack 3.5mm Stereo Socket 3 Poles Square Body
This Jack 3.5mm 3-pole jack with a square body (2 beveled corners)  will allow you to create headsets for your DIY designs
Reference : 12468
2,50 €tax incl.
2,08 € tax excl.
Shipping date: 22-04-2025.
Jack 3.5mm Socket
3 poles, square body (2 beveled corners)
embase jack 3.5mm 3 pôles
This connector for 3.5mm Jack connector has 3 poles and a square body (2 beveled corners). It will allow you to create your own headphone connectors in a DIY design.
Connector typeJack 3.5mm, 3 poles
Body materialPlastic
Body formatSquare (2 beveled corners)
Screw thread total length (without nut)4.6mm
Body length (without screw thread)13.3mm
Screw thread diameter7.7mm
Maximum panel thickness3mm
Cotations embase jack 3.5mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Contacts number3
robust
Everything fine. The Jack seems to be robust.
This review has been posted for Jack 3.5mm Stereo Socket 3 Poles Square Body
