VIBORG VH302G Stereo Jack 3.5mm Connector Gold Plated Ø6mm
The Viborg VH302G is a beautifully designed 3.5mm stereo jack connector, using gold plated copper alloy contacts to ensure very good conductivity. It can accept conductors up to Ø6mm in diameter.
Reference : 15603
11,90 €tax incl.
9,92 € tax excl.
Viborg VH302G
Viborg VH302G Connecteur Jack 3.5mm Stéréo Plaqué Or Ø6mm
The Viborg VH302G is a beautifully designed 3.5mm stereo jack connector, using gold plated copper alloy contacts to ensure very good conductivity. It can accept conductors up to Ø6mm in diameter. The assembly is done by soldering and a hexagonal screw allows a perfect maintenance of the conductor in the connector.
Product typeStereo Jack 3.5mm connector
Contacts materialCopper alloy
PlatingGold
Max conductor diameterØ6mm
InsulationPOM
Mounting typeTo solder
Total dimensions45 x 9.5mm
ColorSilver
Max cable diameter (mm)6.0
Mounting typeTo weld
ConnecticMale
Contacts number3
The Viborg VH302G is a beautifully designed 3.5mm stereo jack connector, using gold plated copper alloy contacts to ensure very good conductivity....
