VIBORG VH302R Stereo Jack 3.5mm Connector Rhodium Plated Ø6mm
The Viborg VH302R is a beautifully designed 3.5mm stereo jack connector, using rhodium plated copper alloy contacts to ensure very good conductivity. It can accept conductors up to Ø6mm in diameter.
3.0 / 5
Reference : 15604
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 25-04-2025.
Viborg VH302R
Viborg VH302R Connecteur Jack 3.5mm Stéréo Plaqué Rhodium Ø6mm
The Viborg VH302R is a beautifully designed 3.5mm stereo jack connector, using Rhodium plated Copper alloy contacts to ensure very good conductivity. It can accept conductors up to Ø6mm. The assembly is done by soldering and a hexagonal screw allows a perfect maintenance of the conductor in the connector.
Product typeStereo Jack 3.5mm connector
Contacts materialCopper alloy
PlatingRhodium
Max conductor diameterØ6mm
InsulationPOM
Mounting typeTo solder
Total dimensions45 x 9.5mm
ColorSilver
Max cable diameter (mm)6.0
Mounting typeTo weld
ConnecticMale
Contacts number3
Déçu
Les points de connexion pour souder les fils ne correspondent pas à la photo et ne sont pas pratiques.
Ce ne sont pas des oeillets. Il faut venir coller le fil sur la partie à souder.
Très peu de filetage pour visser le capot. Se dévisse facilement.
Les côtes sont très différentes des Elecaudio JK3-103 et ne correspondent pas à mon application,
Du coup, commande pour rien, j'ai recommandé les Elecaudio.
This review has been posted for VIBORG VH302R Stereo Jack 3.5mm Connector Rhodium Plated Ø6mm
The Viborg VH302R is a beautifully designed 3.5mm stereo jack connector, using rhodium plated copper alloy contacts to ensure very good...
