AECO AT4-1812G Jack 4.4mm TRRRS Connector Tellurium Copper Gold Plated Ø6.5mm
The aeco AT4-1812G is a high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper, ensuring excellent conductivity and limiting signal loss.
Reference : 18055
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 24-04-2025.
aeco AT4-1812G
aeco AT4-1812G Jack 4.4mm TRRRS Connector Tellurium Copper Gold Plated Ø6.5mm
The aeco AT4-1812G is a high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high purity tellurium copper with gold plating, ensuring excellent conductivity and limiting signal loss. In addition, this model allows convenient cable mounting (max Ø6.5mm) thanks to the parallel orientation of the solder pins. Finally, the stainless steel body is insulated from the contacts by a nylon section.
Product typeMale Jack 4.4mm TRRRS connector
Contacts materialTellurium copper (purity: > 99%)
Contacts platingGold 10µ
Insulation materialNylon
Shell materialStainless steel
Max cable diameterWith reducer: Ø4.5mm
Without reducer: Ø6.5mm
Contacts resistance< 1mΩ
ColorSilver
Total dimensionsØ8.9*43.5mm
Max cable diameter (mm)6.5
Mounting typeTo weld
ConnecticMale
Contacts number5
The aeco AT4-1812G is a high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio...
