AECO AT4-1812R Jack 4.4mm TRRRS Connector Tellurium Copper Rhodium Plated Ø6.5mm
The aeco AT4-1812R is a high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high-purity tellurium copper with rhodium plating ensuring excellent conductivity and limiting signal loss while protecting it from oxidation.
Reference : 18056
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 06-05-2025.
aeco AT4-1812R
aeco AT4-1812R Jack 4.4mm TRRRS Connector Tellurium Copper Rhodium Plated Ø6.5mm
The aeco AT4-1812R is a high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high-purity tellurium copper with rhodium plating ensuring excellent conductivity and limiting signal loss while protecting it from oxidation. In addition, this model allows convenient mounting of a cable (max Ø6.5mm) thanks to parallel-oriented solder pins. Finally, the stainless steel body is insulated from the contacts by a nylon section.
Product typeMale Jack 4.4mm TRRRS connector
Contacts materialTellurium copper (purity: > 99%)
Contacts platingRhodium
Insulation materialNylon
Shell materialStainless steel
Max cable diameterWith reducer: Ø4.5mm
Without reducer: Ø6.5mm
Contacts resistance< 1mΩ
ColorSilver
Total dimensionsØ8.9*43.5mm
Max cable diameter (mm)
  • 6.5
Mounting type
  • To weld
Connectic
  • Male
Contacts number
  • 5
Contacts Material (Connector)
  • Copper
Contacts Plating (Connector)
  • Rhodium
The aeco AT4-1812R is a high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio...
