AECO AT4-1812S Jack 4.4mm TRRRS Connector Tellurium Copper Silver Plated Ø6.5mm
The aeco AT4-1812S is a very high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high-purity tellurium copper with 120µ silver plating ensuring maximal conductivity and limiting signal loss.
Reference : 18058
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 15-04-2025.
aeco AT4-1812S
aeco AT4-1812S Jack 4.4mm TRRRS Connector Tellurium Copper Silver Plated Ø6.5mm
The aeco AT4-1812S is a very high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the audio signal. Its contacts are CNC machined from a single piece of high-purity tellurium copper with 120µ silver plating ensuring maximal conductivity and limiting signal loss. In addition, this model allows convenient mounting of a cable (max Ø6.5mm) thanks to parallel-oriented solder pins. Finally, the stainless steel body is insulated from the contacts by a nylon section.
Product typeMale Jack 4.4mm TRRRS connector
Contacts materialTellurium copper (purity: > 99%)
Contacts platingSilver 120µ
Insulation materialNylon
Shell materialStainless steel
Max cable diameterWith reducer: Ø4.5mm
Without reducer: Ø6.5mm
Contacts resistance< 1mΩ
ColorSilver
Total dimensionsØ8.9*43.5mm
Max cable diameter (mm)6.5
Mounting typeTo weld
ConnecticMale
Contacts number5
The aeco AT4-1812S is a very high-quality Jack 4.4mm TRRRS connector, designed using high-performance components for optimum transmission of the...
