Jack 4.4mm connector TRRRS Gold Plated Ø4mm (Unit) Silver
Reference : 13234
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 29-04-2025.
Jack 4.4mm connector TRRRS Balanced
Brass plated connector ⌀4mm
JACK TRRRS connector 4 conductors
This 4.4mm jack connector with a neat carbon finish. is built with gold-plated brass conductors within a painted metal capsule. It offers good conductivity and mechanical resistance.
Its structure is TRRRS (Tip - 3x Ring - Sleeve). It can thus be used to build a very compact balanced connector.
Weld TRRRS 4.4 jack socket
The base of the cable.is protected thanks to a silicon sleeve that protects the cable conductors against twisting and strong pull.
Jack Format4.4mm / Balanced TRRRS
Contacts materialsBrass
PlatingGold
Max cable diameterØ 4mm
Connection TypeWelding
Weight9g
Body dimensions⌀8.42 x 22.5mm
Total length43.5mm
ColorSilver
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
Contacts number5
