Jack 4.4mm Male Connector TRRRS 5 Poles Gold Plated
This 4.4mm female jack socket is ideal for PCB mounting and will allow you to add an efficient balanced connection to a DIY project. Its contacts are gold plated and ensure a very good electrical conductivity and resistance to oxidation.
Reference : 17746
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 22-04-2025.
Jack 4.4mm CONNECTOR
TRRRS 5 Poles Gold plated
Connecteur Jack 4.4mm TRRRS Plaqué Or Nu
This 5-pole male Jack 4.4mm connector is ideal for a DIY assembly and will allow you an efficient symmetrical connection. Its contacts are gold plated and ensure a very good electrical conductivity and resistance to oxidation.
Product typeJack 4.4mm male connector
Numbers of poles5
Contact platingGold
Mounting typeTo solder
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number5
Great connector, easy to solder
This one has bigger areas to solder wire onto, than the similar one which comes with a screw on sleeve, so this one is a better addition to that sleeve.
This review has been posted for Jack 4.4mm Male Connector TRRRS 5 Poles Gold Plated
This 4.4mm female jack socket is ideal for PCB mounting and will allow you to add an efficient balanced connection to a DIY project. Its contacts...
