AMPHENOL ACPM-GN Male Mono Jack 6.35mm Connector Ø7mm
This 6.35mm male mono jack connector is ideal for professional-quality cable design. Both the plating and the connector body are made of nickel, providing excellent corrosion resistance and durability. In terms of connection, the AMPHENOL ACPM-GN 6.35mm jack connector can receive cable up to Ø7mm diameter, and the connection is made by soldering.
Reference : 18903
3,10 €tax incl.
2,58 € tax excl.
Shipping date: 29-04-2025.
AMPHENOL ACPM-GN Male Mono Jack 6.35mm Connector Ø7mm: front view
AMPHENOL ACPM-GN Male Mono Jack 6.35mm Connector Ø7mm: dimensions
Product typeMale Jack 6.35mm connector
Channels numberMono (1)
Max. Cable diameterØ7mm
Total connector dimensionsØ13.8mm x 79mm
Contacts materialCopper alloy
Contacts platingNickel
Shell materialNickel
Rated current75A
Rated voltage25V
Connection typeTo solder
ColorSilver
Package1x Male Mono Jack 6.35mm Connector AMPHENOL ACPM-GN
Max cable diameter (mm)7.0
Mounting typeTo weld
ConnecticMale
Contacts number2
Contacts Plating (Connector)Nickel
This 6.35mm male mono jack connector is ideal for professional-quality cable design. Both the plating and the connector body are made of nickel,...
