NEUTRIK NP3X Male Stereo Jack 6.35mm Connector Ø7mm
This rugged 6.35 male stereo jack connector is ideal for professional cable design. While remaining thin, the connector uses materials that ensure durability at all times, including a zinc body.
Reference : 13852
5,10 €tax incl.
4,25 € tax excl.
Shipping date: 24-04-2025.
Neutrik NP3X
Neutrik NP3X Connecteur Jack 6.35mm Stéréo Mâle Ø9mm
This rugged 6.35 male stereo jack connector is ideal for professional cable design. While remaining thin, the connector uses materials that ensure durability at all times, including a zinc body. In the same way, the contact is machined in one piece with high precision to prevent breakage.
Product typeMale Jack 6.35mm connector
Channels numberStereo (2)
Min. / Max. Cable diameter4-7mm
Total connector dimensionsØ14.5mm x 93mm
Connection typeTo solder
Contacts materialCopper alloy
Shell materialZinc
ColorSilver
Dielectric strength1kVdc
Insulation resistance> 2GΩ
Rated voltage< 50V
Max cable diameter (mm)7.0
Mounting typeTo weld
ConnecticMale
Contacts number3
Contacts Plating (Connector)Nickel
This rugged 6.35 male stereo jack connector is ideal for professional cable design. While remaining thin, the connector uses materials that ensure...
