DD DJ30A 2021 Female Jack 3.5mm to Male Balanced Jack 4.4mm Adapter Gold Plated
The DD DJ30A 2021 is a compact adapter, equipped with a single-ended female 3.5mm jack connector and a balanced male 4.4mm jack connector. It benefits from a beautiful design, with connectors having a high quality gold plating, the whole dressed in an Aluminium body.
Reference : 15689
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 22-04-2025.
DD DJ30A 2021
DD DJ30A 2021 Adaptateur Jack 3.5mm femelle vers Jack 4.4mm symétrique mâle plaqué Or
In this 2021 version, the DJ30A becomes lighter and has a better finish, thanks to the use of a new aluminum alloy.
Il n'est pas recommandé d'utiliser le DJ30A avec des appareils disposant d'un Jack 3.5mm intégré. Cela peut causer un changement dans la restitution de l'appareil.
Le DJ30A n'est pas compatible avec les lecteurs Sony Digital Music Players / Walkman
Product typeJack adapter
Connectors1x Female Jack 3.5mm
1x Balanced male Jack 4.4mm
Contacts platingGold
Body materialAluminium 6061 alloy
Dimensions16.5 x 18 x 10mm
Weight5.3g
ConnecticMale & Female
ConnectorJack 3.5mm
ConnectorJack 4.4mm
The DD DJ30A 2021 is a compact adapter, equipped with a single-ended female 3.5mm jack connector and a balanced male 4.4mm jack connector. It...
