DD DJ65B Male Jack 6.35mm to Female Jack 4.4mm Femelle Plaqué Or
The DD DJ65B adapter has a 6.35mm stereo male connector and a 4.4mm balanced female connector. It will allow you to use a headphone with a 4.4mm jack connector, common on balanced models, with a device that has a 6.35mm jack. The adapter offers a very nice design quality with high purity copper contacts plated with 24k gold.
Reference : 16258
37,90 €tax incl.
31,58 € tax excl.
Shipping date: 22-04-2025.
DD DJ65B
DD DJ65B Adaptateur Jack 6.35mm mâle vers Jack 4.4mm femelle cuivre plaqué or 24k
The DD DJ65B adapter has a 6.35mm stereo male connector and a 4.4mm balanced female connector. It will allow you to use a headphone with a 4.4mm jack connector, common on balanced models, with a device that has a 6.35mm jack. The adapter offers a very nice design quality with high purity copper contacts plated with 24k gold. The internal wiring uses OCC copper. The whole offers an excellent conductivity for a very good transmission of the audio signal. Moreover, the DJ65B is also robust and elegant with a body made entirely of stainless steel.
Product typeJack adapter
Connectors1x Male stereo Jack 6.35mm
1x Female balanced Jack 4.4mm
Contacts materialCopper
Contacts platingGold 24k
Internal wiring materialOCC Copper
Body materialStainless steel
Dimensions9.9 x 19.5 x 23mm (withouth plug)
ConnecticMale & Female
ConnectorJack 6.35mm
ConnectorJack 4.4mm
3 reviews
Excellent
High quality. with a beautiful design. Recommended.
This review has been posted for DD DJ65B Male Jack 6.35mm to Female Jack 4.4mm Femelle Plaqué Or
Excellent
Excellent adaptateur pour celui qui souhaite utiliser un câble symétrique, terminé par une Pentacon 4,4 mm (de plus en plus généralisée sur les DAP, et ampli casque/DAC) et le relier à une entrée jack 6,35 mm très répandue.
Je souhaitais pouvoir utiliser un câble, symétrique (avec terminaison 4,4mm ,haut de gamme, réalisé par un artisan) sur un ampli lampe OTL.
Mission accomplie grâce au DD DJ65B.
Qualité de fabrication excellente, matériaux de qualité et pas de perte ou d’altération sonore lors de son utilisation.
DDhifi est devenu la référence, me concernant, en termes d’adapteurs entre mes différentes terminaisons de câbles et mes différents amplis/DAC et DAP.
Je possède plusieurs adaptateurs de ce fabricant et tous me donne entière satisfaction.
Un dernier mot, sur le sérieux et la rapidité d’envoi d’Audiophonics: toujours au top, un grand merci !
Excellent !
Fabrication particulièrement soignée et bien conçue. Réalisation et esthétique quasi luxueuses pour ce petit adaptateur. Fonctionnement Parfait ! aucune dégradation constatée lors de l'écoute. Certes un peu cher, mais par ailleurs, introuvable en 6.35 M/4.4 F. Parfait pour mes casques Sivga et Sendy.
The DD DJ65B adapter has a 6.35mm stereo male connector and a 4.4mm balanced female connector. It will allow you to use a headphone with a 4.4mm...
