DD DJ65M Adapter Jack 6.35mm Female to Jack 4.4mm Male Gold Plated Copper
This adapter from DDHiFi features a quality design. It features a 6.35mm TRS female connector and an unbalanced 4.4mm male connector.
Reference : 19793
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 29-04-2025.
DD DJ65M(4.4) Adapter Jack 6.35mm Female to Jack 4.4mm Male Gold Plated Copper
Photo of DDHiFi DJ65M(4.4) adapter
This jack adapter from DDHiFi features a quality design. It features a 6.35mm TRS female connector and an unbalanced 4.4mm male connector. The adapter uses a high-quality Neutrik socket with gold-plated copper contacts for optimum conductivity and resistance to corrosion and oxidation. The whole unit is protected by a CNC-machined aluminum body.
Please note that this is an unbalanced adapter. Consequently, certain contact points on the 4.4mm connector are not used. As a result, only half the power indicated by your device with a 4.4mm jack output will be used.
This adapter is not compatible with Sony brand devices or 4.4mm line-out interfaces, and is exclusively designed for use with headphone output.
Features of the DDHiFi 4.4mm jack connector
Product typeJack adapter
Connectors1x 6.35mm female jack
1x 4.4mm male jack (unbalanced, custom soldering)
Contact materialMonocrystalline copper
Contact plating24k gold
Body materialAluminium alloy 6063
Dimensions (excluding contacts)44x 21.8 x 23mm
Weight22.5g
Package1x DD DJ65M(4.4) jack adapter
ConnecticMale & Female
ConnectorJack 4.4mm
ConnectorJack 6.35mm
