Balanced 2.5mm Male to 4.4mm Female Jack Adaptere
This balanced FiiO LB-4.4M adapter, 8cm long, integrates on one side a 4.4mm female jack connector and on the other side a 2.5mm male jack. This one is mainly designed to allow the connection of a headphone equipped with a 4.4mm jack connector to the 2.5mm jack output of a balanced DAP. The cable integrates PCOCC-A Copper conductors arranged in parallel. Each conductor is protected by an insulating PFA sheath, a PCOCC-A Copper shield and finally an external TPE sheath, in order to protect the signal from interferences. The connectors of the LB-4.4M are gold plated and ensure both good conductivity and resistance to oxidation.
Product type | Balanced Jack adapter |
Connectors | 1x Female Jack 4.4mm 1x Male Jack 2.5mm (TRRS) |
Conductors material | PCOCC-A Copper |
Insulation | PFA + TPE |
Shielding | PCOCC-A Copper |
Connectors plating | Gold |
Length | 8cm |
Color | Black |
Connectic | Male & Female |
Section (mm²) | N/A |
Connector | Jack 2.5mm |
Connector | Jack 4.4mm |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | Gold |
