FIIO LL-4.4M Balanced Adapter Male Jack 3.5mm to Female Jack 4.4mm
This balanced FiiO LL-4.4M adapter, 8cm long, integrates on one side a 4.4mm female jack connector and on the other side a 3.5mm male jack. This one is mainly designed to allow the connection of a headphone equipped with a 4.4mm jack connector to the 3.5mm jack output of a DAP.
Reference : 15137
15,90 €tax incl.
13,25 € tax excl.
FiiO LL-4.4M
Balanced 3.5mm Male to 4.4mm Female Jack Adapter
FIIO LL-4.4M Adaptateur Symétrique Jack 3.5mm Mâle vers Jack 4.4mm Femelle
This balanced FiiO LL-4.4M adapter, 8cm long, integrates on one side a 4.4mm female jack connector and on the other side a 3.5mm male jack. This one is mainly designed to allow the connection of a headphone equipped with a 4.4mm jack connector to the 3.5mm jack output of a DAP. The cable integrates PCOCC-A Copper conductors arranged in parallel. Each conductor is protected by an insulating PFA sheath, a PCOCC-A Copper shield and finally an external TPE sheath, in order to protect the signal from interferences. The LL-4.4M connectors are gold plated and provide good conductivity and resistance to oxidation.
FIIO LL-4.4M Adaptateur Symétrique Jack 3.5mm Mâle vers Jack 4.4mm Femelle FIIO LL-4.4M Adaptateur Symétrique Jack 3.5mm Mâle vers Jack 4.4mm Femelle
Product typeBalanced Jack adapter
Connectors1x Female Jack 4.4mm
1x Male Jack 3.5mm
Conductors materialPCOCC-A Copper
InsulationPFA + TPE
ShieldingPCOCC-A Copper
Connectors platingGold
Length8cm
ConnecticMale & Female
Section (mm²)N/A
ConnectorJack 4.4mm
ConnectorJack 3.5mm
This balanced FiiO LL-4.4M adapter, 8cm long, integrates on one side a 4.4mm female jack connector and on the other side a 3.5mm male jack. This...
