Male Jack 6.35 to Female Jack 3.5mm Adapter Gold Plated Stereo to Screw
This 3.5mm Jack female to 6.35mm Jack male adapter will allow you to connect your headphones or headphones with a 3.5mm Jack connector to a device with a 6.35mm Jack connector.
Reference : 12804
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 06-05-2025.
Jack 6.35mm Adapter
Female Jack 3.5mm to Male Jack 6.35mm Gold Plated Stereo
Adaptateur Jack 6.35mm
This 3.5mm Jack female to 6.35mm Jack male adapter will allow you to connect your headphones or headphones with a 3.5mm Jack connector to a device with a 6.35mm Jack connector. The adapter is gold plated, allowing good signal conductivity and excellent oxidation resistance. On the 3.5mm jack side you will find a screw thread, allowing if necessary to fix the adapter firmly and avoid untimely disconnections.
Adapter typeJack 3.5mm Female to Jack 6.35mm Male
PlatingGold
ConnectionTo screw
ChannelsStereo (3 poles)
Total dimensions40mm x 10mm
Connectic
  • Male & Female
Connector
  • Jack 6.35mm
Contacts Material (Connector)
  • Copper Alloy
Contacts Plating (Connector)
  • Gold
This 3.5mm Jack female to 6.35mm Jack male adapter will allow you to connect your headphones or headphones with a 3.5mm Jack connector to a device...
