OEAUDIO MULTI-PLUG Set of Interchangeable 2.5mm / 3.5mm / 4.4mm Jack Connectors
The OEAudio Multi Plug offers a convenient solution for adapting a cable to different device connections. It is a set of interchangeable connectors, including a 2.5mm jack, a 3.5mm jack and a 4.4mm jack.
Reference : 15320
79,00 €tax incl.
65,83 € tax excl.
OEAudio Multi Plug
OEAudio Multi Plug Set de Connecteurs Jack 2.5mm / 3.5mm / 4.4mm Interchangeables
Compact, with a length of only 20mm for the 3.5mm jack connector, the Multi Plug is also high performance, with an impedance of only 3.5mΩ. Moreover, all connections are protected by the body of the connector to limit interference. The contacts are gold plated to ensure perfect resistance to oxidation and conductivity.
Product typeInterchangeable jack connectors
Contacts platingGold
Shell materialAluminum
Impedance3.5mΩ
Package1x Aluminium body
1x Terminal
1x 2.5mm TRRS jack head
1x 3.5mm stereo jack head
1x 4.4mm TRRS head
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number4
Contacts number3
Contacts number5
The OEAudio Multi Plug offers a convenient solution for adapting a cable to different device connections. It is a set of interchangeable...
