JANTZEN AUDIO 000-0010 4N Copper Air Core Wire Coil 14AWG 0.47mH 53x30mm
Reference : 10486
14,50 €tax incl.
12,08 € tax excl.
Shipping date: 18-04-2025.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,470mH
Tolerance+/-3%
Coil External Diameter53mm
Coil Internal Diameter25,00mm
Coil Height30mm
Wire Diameter1.60mm
Wire Section2.01mm²
AWG14 AWG
Weight0,322kg
Inductance (mh)0.47
Conforme à la description.
Prévue pour un filtre HP. Il faudra la maintenir sur le CI avec des colliers en rilsan.
This review has been posted for JANTZEN AUDIO 000-0010 4N Copper Air Core Wire Coil 14AWG 0.47mH 53x30mm
