JANTZEN AUDIO 000-0057 4N Copper Air Core Wire Coil 4N 14AWG 0.2mH 42x25mm
Reference : 15574
8,10 €tax incl.
6,75 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,200mH
Tolerance+/-3%
RDC0,10Ω
Coil External Diameter42mm
Coil Internal Diameter8,00mm
Coil Height25mm
Wire Diameter1.60mm
Wire Section2.01mm²
AWG14 AWG
Weight0,205kg
Inductance (mh)0.2
