High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
Type | Air Coil Core |
Materials | High Purity Copper 4N |
Inductance | 0,95mH |
Tolerance | +/-3% |
Coil External Diameter | 38mm |
Coil Internal Diameter | 15mm |
Coil Height | 15mm |
Wire Diameter | 0.8mm |
Wire Section | 0.79mm² |
AWG | 20 AWG |
Weight | 0,092kg |
