JANTZEN AUDIO 000-1430 AIR CORE WIRE COIL Copper coil 4N 18AWG 0.85mH
Reference : 16384
6,50 €tax incl.
5,42 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,85mH
Tolerance+/-3%
Coil External Diameter48mm
Coil Internal Diameter15mm
Coil Height15mm
Wire Diameter1mm
Wire Section0.79mm²
AWG18 AWG
Weight0,144kg
Inductance (mh)0.85
