JANTZEN AUDIO 000-1862 4N Copper Air Core Wire Coil 15AWG 0.91mH
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications. The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% ).
Reference : 15566
15,50 €tax incl.
12,92 € tax excl.
Shipping date: 16-04-2025.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,91mH
Tolerance+/-3%
Coil External Diameter55mm
Coil Internal Diameter30mm
Wire Diameter1.4mm
Wire Section1.65mm²
AWG15 AWG
Weight339kg
Inductance (mh)0.91
Excellent !
Utilisé en parallèle Filtrage HP Médium/Aigu c'est juste parfait ! Pas besoin de se ruiner avec d'autres Selfs beaucoup plus chères. De plus, permet facilement de dérouler pour mettre à la valeur voulue/désirée spécifique. Le Top = Noyée dans de la résine durcissante et c'est un MUST ! Qualité du fil = carrément excellente !
Merci AUDIOPHONICS;
This review has been posted for JANTZEN AUDIO 000-1862 4N Copper Air Core Wire Coil 15AWG 0.91mH
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.  The coil benefits from a modern design,...
