JANTZEN AUDIO 000-1896 AIR CORE WIRE COIL Copper coil 4N 15AWG 0.56mH
Reference : 15347
14,90 €tax incl.
12,42 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,560mH
Tolerance+/-3%
RDC0,220Ω
Coil External Diameter49mm
Coil Internal Diameter25,00mm
Coil Height30mm
Wire Diameter1.40mm
Wire Section1.54mm²
AWG15 AWG
Weight0,258kg
Inductance (mh)0.56
