JANTZEN AUDIO 4N Copper Air Core Wire Coil 18AWG 0.22mH
Reference : 12987
3,50 €tax incl.
2,92 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,220mH
Tolerance+/-3%
Coil External Diameter42mm
Coil Internal Diameter20,00mm
Coil Height10mm
Wire Diameter1.00mm
Wire Section0.79mm²
AWG18 AWG
Weight0,065kg
Inductance (mh)0.22
