JANTZEN AUDIO 4N 000-1480 Copper Air Core Wire Coil 20AWG 1.8mH
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications. The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance (+/-3%).
Reference : 16818
6,90 €tax incl.
5,75 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance1.8mH
Tolerance+/-3%
Coil External Diameter42mm
Coil Internal Diameter25mm
Coil Height30mm
Wire Diameter0.80mm
Wire Section0.50mm²
AWG20AWG
Weight0.145kg
Inductance (mh)1.8
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.  The coil benefits from a modern design,...
