JANTZEN AUDIO 000-1752 4N Copper Air Core Wire Coil 4N 21AWG 0.1mH
Reference : 12984
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 29-04-2025.
Audio copper coil Air Coil Jantzen audiophile passive filtering
4N Copper Coil Jantzen Audio
Copper wire of high purity with a inductanse without distortion. It will suit all audio applications.
The coil sees modern design, self-supporting and with a low tolerance to the inductance (± 3%)
The power handling depends on the yarn used, particularly the thickness of the copper wire.
The larger the cable is thick, the more power capacity will be.
This is probably the most versatile reels on the market.
TypeAir Coil Core
MaterialCopper high purity 4N
Inductance (mH)0.1 mH
DRC (Ohms)0.29 Ohm
Coil (mm)15 mm
Cable (mm)0.7 mm
AWG21
Weight (kg)0.024 kg
Diameter / Height20 / 27 mm
free coreYes
Inductance (mh)0.1
