JANTZEN AUDIO AIR CORE WIRE COIL 000-0128 Coil 4N Copper 13AWG 2mH 0.33 Ohm
Jantzen Audio Air Core Wire Coil are made from high-purity copper wire, perfectly wound to create a distortion-free inductor for all audio applications. Their low inductance tolerance of +/-3% and high power handling make them the most versatile coils on the market.
Reference : 20307
48,74 €tax incl.
40,62 € tax excl.
Jantzen Audio Air Core Wire Coil 000-0128 Coil 4N Copper 13AWG 2mH 0.33Ω
The Jantzen Audio Air Core Wire Coil coils are made from high-purity copper wire, offering distortion-free inductance. They are therefore suitable for all audio applications. These coils feature a modern, self-supporting design with low inductance tolerance (±3%). Power handling depends on the wire used and more particularly on the thickness of the copper wire. The greater the thickness, the higher the power capacity. Jantzen Audio Air Core Wire Coils are therefore among the most versatile on the market.
Product typeAir core coil
Material4N copper
Inductance2mH
Tolerance±3%
DCR0.33Ω
Wire diameter1.8mm
Wire Section13AWG
Dimensions & Weight
Outer diameter69mm
Inner diameter35mm
Height60mm
Weight1.082kg
Inductance (mh)
  • 2.0
Jantzen Audio Air Core Wire Coil are made from high-purity copper wire, perfectly wound to create a distortion-free inductor for all audio...
