JANTZEN AUDIO ALUMEN Z-CAP 001-7016 Capacitor 100V 0.68µF
Jantzen Audio Alumen Z-Cap are high-end capacitors using aluminum foil. They are specifically designed for passive filters.
Reference : 20088
29,01 €tax incl.
24,18 € tax excl.
Jantzen Audio Alumen Z-Cap 001-7016 Capacitor 0.68µF 100V
Capacitor Jantzen Audio Alumen Z-Cap 0.68µF 100V
The Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This aluminium-polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors, exaggerating the upper parts of the audio spectrum.
This series has a thinner dielectric than other capacitors on the market. This avoids memory defects in the insulators, for rapid transfer of electrons between each winding (very low resistance in series ESR). Jantzen Audio Alumen Z-Cap capacitors are therefore particularly fast, offering harmonics worthy of the best oiled paper capacitors, without the harmonic colourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS and RADIA tweeters. The solder wires are made of OCC copper. These conductors are also excellent for coupling into transistor amplifiers where the rated voltage is sufficient (100VDC). *** Translated with www.DeepL.com/Translator (free version) ***
Product typeCapacitor
DielectricPolypropylene (PP)
Aluminium metallization99.99%
Capacitance0.68µF
DC voltage100V
AC voltage35V
Tolerance±5%
Max. temperature85°C
Very low induction construction-
PolarisationNon-polarised capacitors
Very low ESR-
Dimensions & Weight
Diameter18mm
Length43mm
Weight16g
Tolerance (%)5
Capacitor capacitance (µF)0.68
Rated voltage (V)100
Capacitor typeFilm capacitor
