JANTZEN AUDIO 000-1760 4N Copper Air Core Wire Coil 17AWG 0.47mH 38x27mm
JANTZEN AUDIO AIR CORE 4N Copper Wire Coil 17AWG 0.47mH
The Jantzen Audio Air Core Wire Coil is made of a very pure copper wire, offering distortion-free inductance. It will therefore be suitable for all audio applications. The coil benefits from a modern, self-supporting design with a low inductance tolerance (+/-3%).
Reference : 15962
6,60 €tax incl.
5,50 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0.47mH
Tolerance+/-3%
RDC0.259Ω
Coil External Diameter38mm
Coil Internal Diameter15mm
Coil Height27mm
Wire Diameter1.2mm
Wire Section1.04mm²
AWG17 AWG
Weight167g
Inductance (mh)0.47
The Jantzen Audio Air Core Wire Coil is made of a very pure copper wire, offering distortion-free inductance. It will therefore be suitable for all...
