JANTZEN AUDIO COMPACT MKT 001-8050 MKT Capacitor 160V 3.9µF
Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors.
Reference : 18723
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 25-04-2025.
Jantzen Audio Compact MKT 001-8050 Axial MKT Capacitor 160V 3.9µF
Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact and giving them better sonic properties than standard film capacitors. With a nominal voltage of 160V DC, these capacitors are also more versatile than electrolytic capacitors, whose nominal voltage is usually only 63V DC or 100V DC. Thanks to their rounded square shape (flat top and bottom surface), they can be easily stacked when it's necessary to couple several capacitors in parallel to achieve a higher capacitance value for a certain crossover position. Stackable, they also take up much less space than equivalent round values.
Technical characteristics
Capacitor typeMKT axial compact capacitor
Voltage rating160VDC
100VAC
Capacity tolerance±5%
Capacity3.9µF
Capacitor foilMetallized polyester foil
Dielectric insulationPolyester foil
Terminal leadsTinned 4N copper wire
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thickness5µm
ESRExtremely low
Dissipation factorExtremely low
Self-inductance< 15nH
Temperature range-55°C / +125°C
Metal layer thickness0.3µm
Metal layer conductivity1.2Ω/cm²
Dimensions (L x P x H)25 x 16 x 12mm
ColorWhite
Tolerance (%)5
Capacitor capacitance (µF)3.9
Rated voltage (V)100
Rated voltage (V)160.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Compact et performant
J'ai utilisé ces condensateurs Jantzen MKT pour le filtre passif d'une paire d'enceinte bibliothèque de 8 litres. J'avais donc besoin de composants de petite taille mais sans trop rogner sur la qualité. J'ai choisi ces condensateurs pour les 4 condensateurs du filtre.
Leur gros avantage est leur compacité. Le fait qu'il soit plat permet aussi un meilleur agencement.
Et à l'écoute, ces enceintes sont super.
Allez y les yeux fermés et en plus, les prix n'ont rien à voir avec des MKP haut de gamme. A t'on les oreilles pour entendre la différence ? J'en doute, il y a tellement d'autres éléments perturbateurs.
This review has been posted for JANTZEN AUDIO COMPACT MKT 001-8050 Axial MKT Capacitor 160V 3.9µF
Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in...
