JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 120µF 5%
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors.
3.0 / 5
Reference : 15481
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 29-04-2025.
Jantzen Audio EleCap Condensateur Électrolytique 100V 120µF 5%
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors, often with a tolerance of ±10%. Both affordable and versatile, they are an excellent choice especially for bass channels or for integration into a crossover with limited space.
Product typeElectrolytic capacitor
Rated voltage100VDC
35VAC
Capacitance120µF
Tolerance±5%
Operating temperature range-40°C / +85°C
Leakage current< 0.003CRUR (µA)
Dissipation factor< 0.1 @ 1kHz
Signal directionNon polarized (bi-polar capacitor)
ESR max.0.13Ω
Dimensions16x34mm
Weight9g
Tolerance (%)5
Capacitor capacitance (µF)120
Rated voltage (V)100
Capacitor typeElectrolytic capacitor
Capacitor formatAxial
Tolérance non respectée
Le prix est très bon mais la tolérance est plutôt à 10 % qu'a 5 %.
120 uf mesuré à 130 uf
56 uf mesuré à 63 uf
80 uf mesuré à 89 uf
@ audiophonics : Il sera intéressant de proposer (avec un surcout) des condensateurs sélectionnés et proches des valeurs annoncées.
This review has been posted for JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 120µF 5%
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of...
