The Jantzen Audio Silver Z-Cap capacitors allow perfect sound neutrality and tonal balance to be maintained. They are particularly suitable for use with a tweeter or midrange in passive high-end loudspeakers, but also as coupling capacitors in an amplifier.
All Silver Z-Cap capacitors are nitrogen-filled, giving more foil per capacitor and no risk of evaporation. The wires are made of silver for maximum conductivity.
Product type | Non-polarised Super MKP capacitor |
Capacitance | 0.82µF |
DC voltage | 800V |
AC voltage | 630V |
Tolerance | ±2% |
Construction | Dual foil |
Format | Axial |
Electrode | Vacuum-deposited aluminium coating |
Wires material | Silver |
Dielectric absorption factor | < 0.5% @ 20°C |
Dielectric thickness | PB=6µm |
Self induction | 0mH |
Insulation resistance | < 100000MΩ @ 20°C |
Temperature range | -55°C / +85°C |
Metal layer thickness | PB=0.4µm |
Metal layer conductivity | PB=2.5Ω/cm² |
Dimensions & Weight | |
Diameter | 19mm |
Length | 43mm |
Weight | 13g |
Tolerance (%) | 2 |
Capacitor capacitance (µF) | 0.82 |
Rated voltage (V) | 800 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
