JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 47μF
Reference : 14931
30,90 €tax incl.
25,75 € tax excl.
Jantzen Audio Standard Z-Cap
Capacité MKP non-polar 47,00μF
The Jantzen Audio Standard-Z Cap series offers affordable audio capacitors for your high fidelity hardware build / repair / upgrade projects. They stand out thanks to their excellent value for money in high audio performance. These capacitors offer a high and fast reaction, detailed sound and a smooth signal compared to what the competition offers in the single polypropylene foil capacitor market.
The dielectric fluid used is nitrogen, which allows denser foil when assembling the capacitor while avoiding the risk of evaporation.
This Jantzen Audio Standard Z Cap capacitor model has a capacitance of 47,00μF for a diameter of Ø 42mm and a length of 59mm.
TypeNon-polarized MKP (single foil lane)
DielectricPolypropylene film
Construction: Round tubular type axial leads
Rated Voltage400 VDC / 250 VAC
ElectrodesAluminum metallized vacuum deposited
ContactsNon-inductive zinc thermally sprayed extended film
CoatingBlue plastic tape wrapped and sealed in black resin
LeadsTin plated oxygen free copper
Tolerance+/- 5%
Dielectric absorption factor=0.5% @20°C
Dielectric thicknessPB=5µm
Self-inductance=15 nH
Insulation resistance=100.000 MOhm@20°C
Temperature coefficient-200°Cx10-6/°C
Temperature Range-55°C à +85°C
Metal layer thicknessPB =1.2 Ohm/cm2
Capacitance47,00μF
DiameterØ 42mm
Length59mm
Capacitor capacitance (µF)47
2 reviews
Tiens ses promesses
Pas simple de faire un comparatif A/B mais utilisé en remplacement sur filtre ELIPSON MELODINE 7 avec d'autres Jantzen et un Jantzen Silver, après 20min d'écoutes différentes le son semble s'être stabilisé. Très ouvert, beaucoup de détails dans les mediums et aigus. Basses droites.
This review has been posted for JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 47μF
Standart Z
Just like promised, sounds detailed fast smooth.
