JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 8.2μF
Reference : 14925
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 23-04-2025.
Jantzen Audio Standard Z-Cap
Capacité MKP non-polar 8,20μF
The Jantzen Audio Standard-Z Cap series offers affordable audio capacitors for your high fidelity hardware build / repair / upgrade projects. They stand out thanks to their excellent value for money in high audio performance. These capacitors offer a high and fast reaction, detailed sound and a smooth signal compared to what the competition offers in the single polypropylene foil capacitor market.
The dielectric fluid used is nitrogen, which allows denser foil when assembling the capacitor while avoiding the risk of evaporation.
This Jantzen Audio Standard Z Cap capacitor model has a capacitance of 8,20μF for a diameter of Ø 20mm and a length of 46mm.
TypeNon-polarized MKP (single foil lane)
DielectricPolypropylene film
Construction: Round tubular type axial leads
Rated Voltage400 VDC / 250 VAC
ElectrodesAluminum metallized vacuum deposited
ContactsNon-inductive zinc thermally sprayed extended film
CoatingBlue plastic tape wrapped and sealed in black resin
LeadsTin plated oxygen free copper
Tolerance+/- 5%
Dielectric absorption factor=0.5% @20°C
Dielectric thicknessPB=5µm
Self-inductance=15 nH
Insulation resistance=100.000 MOhm@20°C
Temperature coefficient-200°Cx10-6/°C
Temperature Range-55°C à +85°C
Metal layer thicknessPB =1.2 Ohm/cm2
Capacitance8,20μF
DiameterØ 20mm
Length46mm
Capacitor capacitance (µF)8.2
2 reviews
Celestion SL6
Merci à Auphonics pour leur rapidité à traiter les commandes.
J'ai choisi les condensateurs ANTZEN AUDIO STANDARD Z-CAP pour mettre à jour mes enceintes Celestion SL6. Ils s'intègrent parfaitement dans le filtre, et le résultat est à la hauteur de mes attentes. Je retrouve pleinement la signature sonore caractéristique des SL6.
This review has been posted for JANTZEN AUDIO STANDARD Z-CAP Capacitor 400V 8.2μF
Excellent rapport qualité/prix
Je les utilise en remplacement de chimiques sur filtres d'enceintes
avec de très bon résultat
Tolérances très serrées , comme toujours chez Jantzen
