JANTZEN AUDIO SUPERIOR Z-CAP 001-0514 Capacitor 1200V 0.33µF
Jantzen Audio Superior Z-Cap capacitors offer very high performance at a reasonable price. They use a double sheet of metallized polypropylene and have a tolerance of just 2%.
Reference : 20044
9,59 €tax incl.
7,99 € tax excl.
Jantzen Audio Superior Z-Cap 001-0514 Capacitor 0.33µF 1200V
Capacitor Jantzen Audio Superior Z-Cap 0.33µF 1200.0V
The Jantzen Audio Superior Z-Cap range consists of high end non-polarized capacitors, designed specifically for audio to enable your audio system to reproduce every nuance and every detail of the signal, while maintaining unrivalled naturalness and realism.
They are particularly recommended for use as high-end tweeter capacitors or as coupling capacitors in amplifiers. All Jantzen Audio Z-Cap capacitors have a nitrogen filling to increase the amount of foil per capacitor, while eliminating the risk of evaporation that can occur in capacitors using oil or other dielectric fluids.
Product typeCapacitor
DielectricAzote
Foil materialDouble sheets of polypropylene metallised with aluminium and zinc particles
Contacts materialPC-OCC copper
Capacitance0.33µF
DC voltage1200V
AC voltage600V
Tolerance±2%
Operating temperature-30°C / +105°C
Non-inductive design-
PolarisationNon-polarized
Dimensions & Weight
Diameter26mm
Length45mm
Weight29g
Tolerance (%)2
Capacitor capacitance (µF)0.33
Rated voltage (V)1200
Capacitor typeFilm capacitor
Jantzen Audio Superior Z-Cap capacitors offer very high performance at a reasonable price. They use a double sheet of metallized polypropylene and...
