Capacitor 800V 10µF
Jantzen Audio's Superior Z-Cap range consists of premium non-polarized capacitors, specially designed for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unrivalled naturalness and realism.
In particular, they are recommended for use as a high-end tweeter capacitor or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that increases the number of sheets per capacitor while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluid.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting restitution or sound performance.
Product type | Capacitor |
Dielectric | Nitrogen |
Foil material | Dual Aluminium with Zinc particules metalized Polypropylene foils |
Contacts material | PC-OCC Copper |
DC Voltage | 800V DC |
Capacitance | 10µF |
Tolerance | +/- 2% |
Non inductive construction | - |
Polarization | No |
Operating temperature | -30°C - 105°C |
Dimensions | Ø46 x 70mm |
Weight | 108g |
