JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.7μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 6593
22,90 €tax incl.
19,08 € tax excl.
Jantzen Audio Superior Z-Cap
Capacitor 800V 2.7µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity2.7µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ30 x 45mm
Poids39g
Tolerance (%)2
Capacitor capacitance (µF)2.7
Rated voltage (V)800
Capacitor typeFilm capacitor
Capacitor formatAxial
Meilleurs rapport qualité prix
Ses condensateurs (avec les mundorf suprême) sont le minimum à essayer si vous voulez entendre une véritable différence en terme de définition et à condition d'avoir un tweeter haut de gamme derrière, comme souvent je ne modifie qu'une enceintes sur le 2 et je fait des comparatif sur un signal mono (enceintes côte à côte) et la il n'y a pas de doute ce condensateurs apporte une scène sonor plus grande plus de définition, sont grand frère le allumen va plus loins surtout sur des compressions, chez mundorf la montée en gamme est moins significative je trouve
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.7μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
