JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 3.3μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
4.7 / 5
Reference : 6594
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 30-09-2026.
Jantzen Audio Superior Z-Cap
Capacitor 800V 3.3µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity3.3µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ30 x 45mm
Poids40g
Tolerance (%)2
Capacitor capacitance (µF)3.3
Rated voltage (V)800
Capacitor typeFilm capacitor
Capacitor formatAxial
3 reviews
étonnant
montés sur des klipsch rb81mk2. derrière un cayin cs 55 KT88
tout de suite on perçoit une image, notamment sur les voix et bien sur avec un bon enregistrement.
aigus très maitrisés mais bien présents et délicats.
un poil trop à mon goût, ça entraine une petite perte de détails fins. je testerai bien les silver de la même marque.
Le plus étonnant est que au bout de 10 h ou plus, le grave remonte de façon spectaculaire. j'ai l'impression d'avoir changé les boomers.
c'est d'autant plus surprenant que ces 3.3 sont sur les tweeters.
D'enceintes plutôt braillardes on passe à du très propre et même beau par moment, en tout cas bien meilleur que l'origine et en plus insaturable. bien sûr vu la taille, ils sont à l'extérieur sur le bornier juste sous les dernières fiches, il y a un peu de place dans l’arrondis.
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 3.3μF
Excellents en tout point.
J'ai refait les filtres de mes Cabasse Caravelle M2 (9 condensateurs et 7 selfs puis une résistance) entièrement avec cette série de condensateurs.
Tout simplement parfaits.
Les dimensions surtout du condensateur 6.8 µF sont impressionnantes, j'ai dû utiliser une plaque de contre-plaqué sur les 2 faces dans mes enceintes.
Ne pas utiliser cependant cette série Z-Cap superior sur haut-parleurs isodynamiques ou à ruban, préférez les Mundorf Suprême Classic dans ce cas.
Livraison Audiophonics toujours aussi rapide, bravo !!
Filtration.
Il est parfait.
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
