JANTZEN AUDIO WAX COIL 000-8060 Wax Foil Coil Copper 12AWG 0.6mH 0.14 Ohm
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Reference : 19888
69,90 €tax incl.
58,25 € tax excl.
Jantzen Audio Wax Coil 000-8060 Wax Coil Pure Copper 12AWG 0.6 mH ±2%
Jantzen Audio Wax Coil 000-8060 : Front view
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Product typeWax Coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
Inductance0.6 mH ±2%
DC resistance0.14 ohms
Coil size71 x 55mm
Wire AWG12 AWG
Weight0,84kg
PackageSold by unit
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter...
