JANTZEN AUDIO WAX COIL 000-8165 Waxed Taped Coil 12AWG 2.5mH
A true vintage treasure, this Jantzen reel is fashioned from 99.9998% pure Copper 12AWG tapes hardened with a polymolecular paraffin wax.
Reference : 15579
139,00 €tax incl.
115,83 € tax excl.
Jantzen Audio Wax Coil
Wax Coil Pure Copper 12AWG 2.5mH +/-2%
Wax Coil Filter Jantzen Audio
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
TypeWax Coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
Inductance2.5mH +/-2%
RDC0,32Ω +/-5%
Coil Height55mm
Wire AWG12AWG
Weight2.088kg
Inductance (mh)2.5
2 reviews
Impressed with fast deliver, great product.
The sound is quite good, slightly better than the Jantzen 14awg wax paper foil inductor coils I have used a couple times in the past. I use these in Klipsch type B-2 crossovers along with Jantzen Superior Z caps-Jantzen Audio Power Cross-caps. After just a few hours break-in, better sound than the expected.
This review has been posted for JANTZEN AUDIO WAX COIL 000-8165 Waxed Taped Coil 12AWG 2.5mH
Seamless transition
Best inductors ever used in my horn speakers crossover. The most characteristic advantage of these woofer coils is a a really smooth transition between the woofer and the squawker.
