JANTZEN AUDIO WAX COIL 000-8200 Waxed Taped Coil 12AWG 4mH
Reference : 14606
159,00 €tax incl.
132,50 € tax excl.
Jantzen Audio Wax Coil
Wax Coil Pure Copper 12AWG 4,000mH +/-2%
Wax Coil Filter Jantzen Audio
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
TypeWax Coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
Inductance4mH +/-2%
RDC0.43Ω +/-5%
Coil External Diameter122mm
Coil Height55 mm
Wire AWG12AWG
Weight2,561kg
Inductance (mh)4.0
