Acheté en remplacement de Self Mundorf CFC16 un vrai écart non suggestif plus de naturel, fluidité et précision la taille semble compter elle font le double de volume sur les mêmes mh valeurs que les CFC16
Wax Coil Pure Copper 14AWG 1,000mH +/-2%
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 14AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Type | Wax Coil |
Materials | ETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper |
Inductance | 1,000mH +/-2% |
RDC | 0,27Ω +/-5% |
Coil Height | 37 mm |
Wire AWG | 14AWG |
Weight | 0,6290kg |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Rudolphe D.
