celles ci sont utilisées juste avant les médiums aigus, redonne du gain et du détail à recommander
Wax Coil Pure Copper 14AWG 2,000mH +/-2%
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 14AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Type | Wax Coil |
Materials | ETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper |
Inductance | 2,000mH +/-2% |
RDC | 0,40Ω +/-5% |
Coil Height | 37 mm |
Wire AWG | 14AWG |
Weight | 0,9250kg |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
franck C.
franck C.
