JANTZEN AUDIO WAX COIL 000-9120 Waxed Taped Coil 8AWG 1.2mH
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 8AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance.
Reference : 15367
215,00 €tax incl.
179,17 € tax excl.
Shipping date: 16-04-2025.
Jantzen Audio Wax Coil
Wax Coil Pure Copper 8AWG 1.2mH +/-2%
Wax Coil Filter Jantzen Audio
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 8AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Characteristics
TypeWax Coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
Inductance1.2mH +/-2%
RDC0,09Ω +/-5%
Coil External Diameter123mm
Coil Height55mm
Wire AWG8AWG
Weight3.85kg
Inductance (mh)1.2
A true  vintage  treasure, this coil by Jantzen is made from 99.9998% pure Copper 8AWG ribbons hardened by a polymolecular...
