JANTZEN AUDIO WAX COIL 000-9200 Waxed Taped Coil 8AWG 2mH
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 8AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance.
By buying this product you get 28 loyalty points
Reference : 15366
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 18-04-2025.
Jantzen Audio Wax Coil
Wax Coil Pure Copper 8AWG 2mH +/-2%
Wax Coil Filter Jantzen Audio
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 8AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Characteristics
TypeWax Coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
Inductance2mH +/-2%
RDC0,13Ω +/-5%
Coil External Diameter140mm
Coil Height55mm
Wire AWG8AWG
Weight4.76kg
Inductance (mh)
  • 2.0
A true  vintage  treasure, this coil by Jantzen is made from 99.9998% pure Copper 8AWG ribbons hardened by a polymolecular...
