Keystone RJ45 Header
This Keystone socket is intended for use with plastic wall plates. ( Example:Keystone Plastic Wall Plate 1 Location)
This product is used in conjunction with the dedicated plates allows you to organize the inputs outputs of your wall wirings.
Specifications:
Material | N/A |
Mounting type | To connect |
Connectic | Female |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | N/A |
Connector | RJ45 |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Internal width | N/A |
Internal depth | N/A |
Internal height | N/A |
